hawkeye tires
Old Mar 12, 2007 | 08:07 AM
  #21
rdeeno's Avatar
Default hawkeye tires
My mudlites are on the factory wheel and they just fit. Most aftermarket alum. wheels have more offset and may require some trimming to the fender lips. LOL
Old Mar 12, 2007 | 12:08 PM
  #22
Rickeyparker's Avatar
You can put 25 inch tires on the hawkeye, dont go with anything bigger, the Ideal tire would be some 24 inch Mudlites, these wouldnt hurt the hawkeye any at all, the only problem they cause is the speedo will be off 5 mph so if your speedo is showing 25 your doing actually 30, and they do rob a little power from you, im figuring with 25 inch tires you will need to get the dynojet carb kit, add some 108 octane boost and run some high premium fuel with a splifire plug and change the rollers on the clutch and you will have a honda eating machine and it will eat up the road, Ive topped mine out at 50 MPH and it has never been stuck even in the snow. v Bu the 25 inch tires slip right onto the factory rims .
Old Mar 12, 2007 | 11:10 PM
  #23
Vlastic's Avatar
Thanks for the advice. I don't need the speed. Just more traction in the snow and uphills. Thanks again.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
snowolson
Aug 31, 2015 03:51 PM
