transmission chain
Old Feb 17, 2007 | 10:29 PM
bigjimdiesel's Avatar
Default transmission chain
Would someone please tell me how much slack this chain should have or what the length should be? I think it is jumping off of the gears under hard acceleration. oh yea it is a 97 trail blazer 250 thanks.
Old Feb 18, 2007 | 09:50 AM
ftwflh's Avatar
A rule of thumb that I use is when you split the tranny cases you replace the chain
Old Feb 20, 2007 | 10:31 PM
Russ136's Avatar
When you replace the chain, should you also replace the gears/shaft as well. How reliable are these chains. I have 2 scrambler 4x4's.
Old Feb 20, 2007 | 11:04 PM
ftwflh's Avatar
No need to replace the gears unles they are bad.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
