WINCH PROBLEMS
Old Feb 26, 2007 | 12:16 PM
bigbwb's Avatar
Default WINCH PROBLEMS
I have a 2006 Sportsman 800 and it came with the winch (I think its a polaris one). The issue is that I have had the winch in for repair twice now and it still is giving me problems. The in/out switch begins to not work and all I get is a click sound and nothing happens. The dealer has replaced the solenoid twice now and it will work fine for a couple uses then slowly becomes unresponsive.
Are there any other suggestions to give the dealer, beacause whatever they are trying seems only to be a temporary fix.
Thank you,
Brandon
Old Feb 27, 2007 | 02:04 AM
opie1har's Avatar
Check the first page of this polaris forum. There is a winch recall. That might be your problem. Hope this helps.
Old Feb 27, 2007 | 12:47 PM
Toycrazy's Avatar
I had the same thing with one of mine, I had taken it apart to clean and when I put it back together it started doing this, I was finding out it was a bad connection where the two wires go into the winch or in that same area in side the winch.
Old Feb 27, 2007 | 09:52 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
they did have a recall, but if its a warn 2500 its more then likely the newer type and not the 8 post. make sure all connections are tight, because it sounds like its not contacting.
Old Feb 27, 2007 | 11:06 PM
RticKwad's Avatar
Runs Stealth!
I got my 2500 Warn in 06' after my quad
purchase. How do I know if its recalled?
R'
toonces
Oct 19, 2015 02:21 AM
user493
Aug 13, 2015 12:54 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
