HELP...2000 TrailBlazer...
Old Apr 3, 2007 | 09:49 PM
BourneTrailBlazer250's Avatar
Default HELP...2000 TrailBlazer...
I would just get rid of the oil injection, that's what I did to my old trailblazer, gave me piece of mind and it also leaves one less thing to break...
Old Apr 4, 2007 | 12:21 AM
satidwell's Avatar
Originally posted by: Budman650
Originally posted by: satidwell
well, i fired up...didn't think it was getting in spark!, it ran for a few seconds, when I gave it some gas once it hit kinda high on the rpm, it felt like it wasn't getting any more spark?? then it went dead.
and now it won't crank, only turn over.
I'm a little confused, "won't crank, only turn over"?
If it dies when you give it throttle, there is a safety device. The throttle cable may be out of adjustment. There are some contacts in the box on the handlebars that cut out spark if the throttle sticks wide open. Just an idea.
it will not start...the engine is turning over, but i'm not getting any fire that I can see with the spark plug pulled out while cranking.
Old Apr 4, 2007 | 12:39 AM
Budman650's Avatar
Do you have the spark plug touching the block or some sort of ground, otherwise you won't see a spark at the electrode?
Old Apr 4, 2007 | 12:45 AM
Budman650's Avatar
Also, 2manytoys asked if you did a compression check. If you don't have a compression gauge,there is an alternative , though primitive. Put your finger over the spark plug hole. if it doesn't feel good, you have no compression.
atvchic022
Mar 14, 2009 09:59 AM
goldtoesox
Nov 2, 2006 01:56 PM
bansheerider101
Mar 2, 2005 12:58 PM
Jayblazer
Nov 11, 2003 02:42 AM
curb
Apr 7, 2003 06:44 PM
