2000 xpedition tire size upgrade (26?, 27?)
i think 26" would be a better choice. again if you have say 8" wide tires and try to go to 9 or 10" wide is where the trouble begins. just look at tthe distance between the stock tires on now and say the tie rods or the strut and see if another 1 or 2" will fit w/out putting spacers or differnt rims on.
26" on off-set rims is as big as you can go before hitting the front fender wells. Any bigger will clear going straight but interfere when you are turning. Having had an Expedition (loved it) I had 25" 589's on it with stock rims, but lost about 8 MPH on the top end. Loved the way it pulled through the mud and it surprised allot of people with independent rear susp. Downside was in certain conditions I was hunting between 2nd and 3rd gear (particularly snow), 2nd was too high 3rd too low. Just needed a bit more power. If you go bigger tires invest in some extra power as well. Got a pic of the rears in my profile. I will try and post a front.
Hopes this helps
Totun
Hopes this helps
Totun
