Trailblazer Brakes?
Old Apr 29, 2007 | 12:57 AM
brutus450's Avatar
Default Trailblazer Brakes?
did you try my siggestion? pump the crap out of em - it may take a while - just keep doin it
Old Apr 29, 2007 | 03:38 AM
Jester2899's Avatar
Yupp i pounded on it with 2 bricks on top it for 10 minutes then i got mad and stabed a srew driver down it and stomped on the screw driver but nothing
Old Apr 29, 2007 | 03:59 PM
trailblazermudrunner's Avatar
i NEVER use mi back bracke peddle if i have to stop quickly i just grab the handle and put mi weight to the back of the bike
Old Apr 29, 2007 | 04:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i tired using a 2.5 gal can of case on it for overnight a couple of times. it didnt bring it back totally but a little. it worked last yr but sitting over the winter it stopped working.
Old Apr 29, 2007 | 04:30 PM
  #15
Jester2899's Avatar
anybody know what rear caliper is compatible with the an 01 trailblazer 250?
Old Apr 29, 2007 | 09:41 PM
  #16
Budman650's Avatar
Originally posted by: BGRDTRUK
I had the same problem with mine...I bleed the heck out of it and it's fine now works like new and has lasted well over a year now. (when I say I bleed it....I mean I bleed it 50 or more times....I went through a 8-10 ounces of fluid basically I bleed it enough to change all the fluid)
Make sure to bleed both front and rear at the rear.
My best guess is air gets in the system and works its way to the highest point and needs to be pushed all the way back out.
The problem is the rear brake master cyl is at the floor board height and the caliper is a little lower but the hose runs up to the frame area then back down to the caliper.
You are correct, BGRDTRUK.
The front master cylinder is separate from the rear floor pedal master cylinder. The floor pedal will always lose pressure.
There are 2 bleeders on the rear caliper. Find the one that the pedal uses and bleed that one, not the hand brake.
Old Apr 29, 2007 | 09:47 PM
  #17
Jester2899's Avatar
Yea me and my dad bled them both, we did it about 2-3 times, next weekend or when he gets the time ill ask if we can blead them a couple more times
Old Apr 29, 2007 | 11:28 PM
  #18
BGRDTRUK's Avatar
Bleeding it 2-3 time won't do much, like I said before the air in the line is at the highest point and needs to be purged out if you stop and eat lunch then plan on finishing later the air will just bubble back up to the highest spot and you'll have to start over.
One thing that can help is to compress the rear end with a strap and then jack the rear end up so the caliper is the highest point but it could still take a while to get all the air out of the system.
Hope this helps
Old May 1, 2007 | 11:50 PM
  #19
TBJAY's Avatar
this may work also may not be the best but take the cap off the rear master and let it sit over night in a very dry place the air should work its way up you may need to pull the brake line down so the highest point is the naster cylinder. worth a shot.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
chewy78
Sep 8, 2015 10:37 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
