06 sportsman 700 sputters at high rpm, help?
Hey guys, I have a 06 Sportsman 700 efi. It has about 12 hours on it so far, I went out today and bought a new UNI air filter and all the oil to do the first oil change on the quad ever. I threw on the new UNI air filter and took the bike for a spin and I noticed when I gave the quad full throttle it sputters at about 4,000 rpm. It drives fine and half throttle and does not sputter at all from a roll. So I thought maybe the new air filter was casuing a problem. So I threw the old stock filter back on and took it for another spin. Sure enough, same result.. off the line it takes off with plenty of power at full throttle, then when it gets to about 4,000 rpm it sputters (feels like it cuts out for a second, then keeps going). I have no idea what is going on, It has never done this before. Could the spark plug be bad? kinda odd for a brand new quad, but anything is possible.
I need some help or input from people who might have had this same problem or might have heard of this? I did not buy the aftermarket warranty and since I have not done the first oil chagne it should still be under factory warranty.
Nee some help guys.. Thanks.
Its kinda odd, not really like when your backing up. Cause that is sputtering the whole time, The bike runs great until its give WOT and hit about 4k rpm. Then it feels like the whole bike cuts out for a second and then resumes power through the rest of the power band.
A few years ago, I had Z/28 camaro that would do the same thing. I took it in and the plugs were fouled. Maybe its the same thing?
Just got done riding thembike again, now its starting to sputter less but its still doing it none the less. My local dealer's service department is closed on sunday and monday so I wont be able to take it in untill tomorrow.
I could still use some more opions though.. Thanks guys.
Oaklandr8ersfan: Sorry to hear about your problem.I have also heard the same thing happing about using to much filter oil.I wounder if you put in some fuel injector cleaner like for an automobile if it would clean it up after riding around for awhile.I think it would be worth the try. I use a K&N and worry evertime about using to much oil spray. Mudrooster
Oakland fan - I had the exact same issue on my 05 700efi. In my case the snorkle that goes upward from the forward top portion of the air box cover was jamming into the foam material at the rearward portion of the gas tank. Art least for the 05 there is a piece of foam back there with a cut out for the snorkle to go through. At any rate check to ensure there is no plugging of any sort on the air intake. Hope this helps.
