96 425 magnum
96 425 magnum
New cover also seems to be made of a different plastic composition that the other with a lower styrene content. It is less brittle than the old one. It is also suppose to have more room inside for the belt and internals so that you don't ave the same problems with clearance. This was also a problem with the older cover as it tended to shrink with heat and age which cased the internals to rub on and eventually right through the cover.
Invest in a new cover and gasket and while you've got it apart you might want to check the belt and replace it while you have everything torn apart. If it had been rubbing on anything it may need replacing too. Button everything up and you should be good as new. It will run a lot quieter as a bonus.
09-09-2015 06:57 AM
