Polaris 4x4 Struts
Old May 24, 2007 | 02:27 AM
PoRider's Avatar
Default Polaris 4x4 Struts
Hello.
I have a 96 Sportsman that has a front wheel that has excessive runout. It appears that the part of the strut (insert?) just behind the coil is loose and allows the entire bearing assembly to move like there is a bad wheel bearing. Wheel bearings are fine. The part that is loose houses the bearing cups and the bearings. Is there a fix for this, or a way to tighten up the insert? Is the insert removeable?
Old May 24, 2007 | 07:27 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you sure the 2 bolts that hold the strut in place didnt loosen up allowing it to move up in down in the strut housing?
Old May 24, 2007 | 12:44 PM
PoRider's Avatar
Thanks for the reply. The McPhearson strut itself is tight. Its in the knuckle that I am concerned with. Where the bearings are in the knuckle (behind the electric coil) and where the axle spindle passes through is loose. Can this be repaired?
I can look at the back and see the housing move when I wiggle the 4x4 coil attached. How are these coils attached? How is the housing put in there? Pressed?
For an example Pic: http://www.bigbuckatvproducts....ruts_95_scrambler.htm
Thanks for any help.
RobJ
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
