01 Sportsman Problem?????HELP?????
Old May 26, 2007 | 01:44 AM
01Sportsman's Avatar
Default 01 Sportsman Problem?????HELP?????
I Have a 2001 Sportsman 500 H.O. that will start right up and sit there and idle but the minute i start to give it gas it startes to pop and backfiring then when i let off the gas it will go right back down to an idle.ive tried everything i can think off and i am lost on this one. If anyone can help me out that would be great.
Old May 26, 2007 | 10:36 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you pull the plug and see if its running lean (white)? also it might be a bad cam w/ the lobes worn down.
Old Jun 1, 2007 | 11:26 AM
edmo500's Avatar
sounds like a cam problem to me!
Old Jan 23, 2008 | 11:21 AM
martymoe's Avatar
if it's fuel injected, that sounds like a bad tps
Old Jan 23, 2008 | 02:38 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its a carb model. nice looking rzr.
Old Jan 23, 2008 | 07:59 PM
Kerbbirds's Avatar
try adjusting the Etc, there is an adjustment in the throttle cable about 4 inches from the thumb throttle , adjust it till there is only 1/8 inch of slack in the cable.
Kerbbirds's Avatar
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
