Hawkeye questions.
Old May 27, 2007 | 01:14 AM
ozarkhunter's Avatar
Default Hawkeye questions.
How is does the hawkeye do on hill climbs and low speeds with out the low gear option? Kinda like going over rocks and logs. I read something about the clutches redesigned for this bike what is different. Also how would it compare to the prairie 360?
Old May 27, 2007 | 01:51 AM
00XJ's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ozarkhunter
How is does the hawkeye do on hill climbs and low speeds with out the low gear option? Kinda like going over rocks and logs. I read something about the clutches redesigned for this bike what is different. Also how would it compare to the prairie 360?</end quote></div>
Other than when it sank into some soft sand, the stock tires being part of the problem, I have yet to find anyplace the Hawkeye won't go. Mud, sand, hills, creekbeds, you name it. I have since mounted up a set of Swamp Fox tires though.
I read that Polaris did something different with the clutches, what I don't know. I've never ridden a Prairie 360 so I can't compare the two. I don't have too much experience seeing that my Hawkeye is my first ATV, but IMO the Hawkeye is one heck of a deal for what all it comes with.
Old May 27, 2007 | 02:57 AM
XavierOnasis's Avatar
Hawkeye goes anywhere. The concept of low & high range is irrelevant in this design.
I don't know anything about the Kawi.
Old May 28, 2007 | 01:09 AM
sheepdogMSP8117's Avatar
The Hawkeye does great at low speeds. I can crawl up steep hills and chug through mud and sand at 3 mph all day long. The low range seems to be built in, way different than the Sportsman with a selectable low range.
The stock tires are crap, I'd suggest 23" Swamp Fox tires as a cheap upgrade. I have the 24" and they are slightly large for my preference.
Old May 28, 2007 | 01:41 AM
00XJ's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: sheepdogMSP8117
The stock tires are crap, I'd suggest 23" Swamp Fox tires as a cheap upgrade.</end quote></div>
Exactly what I did.
BTW, my Polaris dealer said that if Polaris states no bigger than 23" tires, since that is the biggest they sell for the Hawkeye you'd better not go larger. If you break parts he said Polaris will not cover it. His example was a Sportsman, which I guess 26" is what is the largest recommended. A guy put 27's on it, and broke cv joints, or axles.. can't remember which. Polaris said, "your problem, we said 26" is the recommended largest size".
Old May 28, 2007 | 09:47 AM
TennesseeTider's Avatar
I put 25" mudlites on mine and it has no problem with them. Just my $0.02.
Old May 28, 2007 | 12:55 PM
Sounds good, thanks guys.
mark23
Oct 1, 2015 09:57 AM
bigred20653
Sep 19, 2015 02:11 PM
snowolson
Aug 31, 2015 03:51 PM
Anomers
Aug 16, 2015 11:06 AM
Sportsman850
Jul 31, 2015 04:25 PM
