2004 Vs. 2004.5 Sportsman 500 HO
Old Jun 10, 2007 | 11:34 AM
skyharborcowboy's Avatar
Default 2004 Vs. 2004.5 Sportsman 500 HO
What are the differences between the two and how can you tell which is which? What is the serial number that the change was made?
Joe
Old Jun 13, 2007 | 03:38 PM
It seems that the fuel gauge and the transmission are the only two items I have been able to track down so far as the differences between the two models. I havent heard a peep from Polaris to my inquiry either which is disappointing!
Joe
Old Jun 13, 2007 | 07:10 PM
Mud Boggin's Avatar
Well mine was made in July of 04 so would it be a 2004 or 2004.5?
Old Jun 13, 2007 | 08:25 PM
cweg1's Avatar
Here goes. 2004.5 has:
An electronic fuel guage in speedo housing
The shift pattern is straight up and down in a row, 04 has a sort of H pattern
The front wheel hubs don't have fillers for hub fluid
The AWD is engaged in the front diff not in the hubs.
The last is the most important. Polaris went to this because they "had good luck with it in the 600"
Old Jun 13, 2007 | 09:19 PM
Mud Boggin's Avatar
Thanks cweg1.
Old Jun 14, 2007 | 10:45 AM
02magnum500's Avatar
Gets his share of deer.
Dont forget about the new radial tires that they upgraded to. If I recall the shift pattern is still straight for the 04's not the H style. The 04.5's are worth the upgrades in my mind.
Old Jun 14, 2007 | 12:03 PM
Cryokid's Avatar
I have a 2004 Sportsman 400 and the shift patern is the "H".
The rest is accurate.
Old Jun 14, 2007 | 06:37 PM
cweg1's Avatar
I learned all of this the hard way. I thought mine was an 04 and couldn't figure out why things were always different.
Old Jan 18, 2009 | 09:45 PM
blamkin86's Avatar
Bringing this old post back from the dead... I believe I just bought an 04.5; I have everything listed above (straight shifter, fuel gauge, front diff).
What really convinced me was the 2004 owner's manual.
What they show for the 2004 500 diff is not at all what I have...
... the 2004 600/700 diff is what's on my bike.
Other than the obvious internal differences, the drain plugs are in completely different locations.
Hope that helps someone else.
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
bradco
Aug 21, 2015 08:11 PM
Stirling
Aug 9, 2015 01:49 PM
