Engine Swap
Old Jul 6, 2007 | 02:06 AM
trabmai796's Avatar
Default Engine Swap
I was wondering if anyone knew if the engine swap i need to do would work. I will be removing the engine from a 1988 polaris trailboss and putting it on a 2000 polaris trailblazer they are both 250cc 2 stroke engine just the 88 is bored out and a lot faster and the 2000 is....dead. Would these 2 match up?
Old Jul 8, 2007 | 12:24 PM
trabmai796's Avatar
Default Engine Swap
Anyopne know anything about this...need to know before tuesday
Old Jul 8, 2007 | 01:36 PM
drlang's Avatar
Default Engine Swap
Will it work? Probably. For about $150.00 you can rebuild the topend on your 2000. If that is what's wrong, and save yourself alot of work. Doc
Old Jul 9, 2007 | 06:16 PM
trabmai796's Avatar
Default Engine Swap
it has a lot wrong with it the electric start went out the brakes went out the air filter fell off and dirt got sucked in2 it and it started like trying 2 cut off and then it just died and never started again plus this other engine is bored out completely and has a new carb and an electric start comes with it also so it wuld be more worth it 2 just take the 88 off and put it on the 2000 frame as long as it fits
bzdok1234
30
Feb 23, 2016 01:55 PM
toonces
Jul 28, 2015 01:58 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
