has the part changed or what???
Old Jul 16, 2007 | 12:46 AM
polarisbear500's Avatar
Default has the part changed or what???
hey all, my steering is loose to the point i can lift up on the handle bars and they will give about an 1/8"-1/4". i talked to polaris and they said it was the rubber bushing in there that was prolly bad, so i ordered the bushing from partsland.com. but when i came in the mail, i got a metal looking washer, not a rubber one???? did i order the wrong thing? please look at this site below, i ordered #6. thanks
http://www.partsland.com/index...SMAM-500-STEERING-POST
Old Jul 16, 2007 | 02:52 PM
SCRAMMYTODD's Avatar
Looks like you ordered the "bushing" but I thought from when I had my Scrambler apart there was a bearing in there, but I don't see one in that picture
Old Jul 16, 2007 | 03:04 PM
scootergptx's Avatar
Supersock
Hired Gun!
I think what you needed to order was part # 11.
Old Jul 16, 2007 | 03:10 PM
POMAG's Avatar
I had the same problem with my 2000 Sportsman 500. The handle bars could be pulled up about 1/4 inch. I found that tightening the castle nut at the bottom of the steering column took care of the problem. After jacking up the front and taking the left front wheel off, I could get to it. Take the cotter pin out and tighten the nut as much as needed. Replace the pin and he problem is solved. There were a couple of washers on the column, but I couldn't see where anything had worn to cause the looseness.
Old Jul 19, 2007 | 01:52 AM
thanks all, POMAG, i found i had the same problem, the nut was loose. tightened it up and boom, no more looseness. thanks again
Old Jul 19, 2007 | 09:16 AM
ftwflh's Avatar
Part 11 was what you needed.If you have a 7/8 post you can get an HPD part that is billet alluminum with a grease fitting.they may make one for the 1'' post now.Check at www.hpd-inc.com
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
Jkfx400P
Jul 6, 2015 10:04 AM
Elad Cohen
Arctic Cat Side By Sides
Jul 4, 2015 02:26 AM
