28+ tires on a 700 mv
Well i want to put the biggest tires possible on my MV.It is for ground clearance...I am curently working on a lift...The rear is almost done.I cut the shocks brackets on the lower A arms and welded a longer set.I also made longer sway bars.It is good for about 2" more ground clearance.tomorow im going to attack the front end...
So do you guys think i can fit 30" mudlite in there?I will run spacers or offset rims if needed.Im not sure if 30" would clear the fenders?
Very impressive, I never lengthened my sway links. I removed them all together. DO NOT do that on the heavy MV. Slight off camber hill climbs gave me a very unsettling flipping back/rolling over feeling! Hey I am jealous, you have your shocks on the lightest setting. Mine was on the stiffest and the 28" Zilla's still rubbed the steel rack sometimes!
I pretty much made my mind on the tires im going to get...Its either swamplites or mudlites.Im leaning toward the swamplites 29½x10x12 front and rear.
I worked on the front end this morning,Im going to put a 1 ½" spacers under the front shocks so it will raise the front by about 1 ½ and i made a set of steel spacers to put under the springs...they are 2 ¾" tall...So that way it will remove most of the front end sag.
09-30-2015 01:37 AM
