k&n airfilter at high altitude/to much air?
Old Aug 24, 2007 | 11:37 AM
oinkjackson's Avatar
Default k&n airfilter at high altitude/to much air?
met a guy on an atv jambori that was having problems at high altitude keeping his quad running..it would start run for a minute and die this was going over a mtn. pass at about 10k anyway to make a long story short. the same guy was in my group of riders a few days later.i asked him if he figured out his previous problem.he told me yes and said the problem at high altitude was caused by his k&n airfilter..apparentely the better breathing k&n filter was causing a problem by confusing his efi computer and it wasnt adjusting for the extra airflow. he switched back to stock filter and bike ran fine over the mtn. passes. i was wondering if anyone has ever herde of this or had this problem.also i should mention that it wasnt a polaris the guy was riding. it was a honda rancher or maybe a forman? i was thinking of putting k&n on my bike but now im not sure because i often ride over 10-12k mtn. passes
Old Aug 24, 2007 | 12:10 PM
2TV's Avatar
2TV
Actually in theory too much air is not an issue as you are ascending. The higher up you go, the more air you need to keep the fuel / air mixture at the proper ratio if the rate of fuel delivery does not change. One way to compensate is to change to a smaller jet (less fuel to go along with less air) at higher altitudes (for carburetor equipped units). Another way is to increase the air flow to keep the fuel / air mixture the same when the fuel delivery rate has not changed (no jetting change). However on a FI unit (depending on the computer / sensor setup) I can see where changing the airflow rate can confuse the fuel / air mixture computation...
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
