Clutch kit sportsman 800
Old Sep 8, 2007 | 12:05 AM
Mud Hog's Avatar
Default Clutch kit sportsman 800
I know it's been asked before, but what is the clutch of the moment for the Popo 2007 800?
Old Sep 8, 2007 | 12:33 AM
ftwflh's Avatar
If you want a complete kit go with a Dalton kit and get it from Rick Ritter.
But if you want to do it your self drop the weights on gram,go with an EPI pink primary spring and the next lighter TEAM secondary spring.This will compensate for big tires.
Old Sep 8, 2007 | 12:34 AM
Mud Hog's Avatar
Appreciate the info, where does one find Rick Ritter?
Old Sep 8, 2007 | 12:39 AM
ftwflh's Avatar
Call him on the phone @ 618-644-3211He will explaine how and why you need anything.Bet he sets you up with a Dalton blue spring and a set of weights.
Old Sep 8, 2007 | 12:45 AM
Mud Hog's Avatar
Again, thanks for the info. I don't care about the top end, only the hole shot. Perhaps he can do the trick.
Old Sep 8, 2007 | 03:16 AM
700vtwinman's Avatar
What will the clutch kit do for the sp800?
Old Sep 8, 2007 | 09:13 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: Mud Hog
Again, thanks for the info. I don't care about the top end, only the hole shot. Perhaps he can do the trick.</end quote></div>
i did some testing w/ differnt springs that rick sent me and i settled w/ the dalton primary spring which is what they recommend for 27" tites/ you do not need to change the weights at all or change the secondary spring if you stay w/ 27" tires. on my 06' in order to put the complete clutch kit(which rick sent me to try) you would have to do a little gringing on the clutch to make the weights work on the install. i was not prepared to alter the clutch as its a balanced product. anyways dalton recommends using there orange/blue spring(which you can oreder thru rick riiter
Old Sep 8, 2007 | 09:55 AM
Mud Hog's Avatar
Hey Stendori, I have basically the same set up as you with the 27" xtr tires. I am definately not going to do any grinding or anything like that. With just the spring, how much hole shot did you gain and did you lose any top end to speak of. Also, what is the top end on your new 08?
Old Sep 8, 2007 | 01:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
with this spring you do not loose any top end speed as it retains its top rmp's unlike some which make you go over your power band and make loose power. basicly it raises your clutch engagment from around 1350 to 1850 rpms and makes it a little jerky w/ take off(from the higher rpms) but no drastic changes. i noticed on my 06' it would make so i could wheelie again w/ all the extra weight from the tires and other stuff on front. it also was helped in not using the lowrange as much when i was going slow(not in the mud though) and was happy enough that i made the dealer change back over to the stock spring and gave me back my dalton spring. i havent put it in my 08' as of yet, but will sometime. maybe next year before mud season. as far as top end speed, not sure as its still breaking in w/ onlu 100 miles on it in 2 rides, but i think ive had it at 64 w/ the big tires on it.
Jmuddin284
Jan 19, 2026 07:16 AM
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
