polaris 500efi electrical problem
#21
<div class="FTQUOTE"><begin quote>Originally posted by: RStormo
Yes, please post part number here. I have had the same problem and solved it as melk54 described.</end quote></div>
What year do you have? Not sure it matters but I don't want to give the wrong info.
#22
Hey guys i have a 06 500 efi. Where abouts should I be looking for this connector. Is it on the drivers side? I haven't had to many problems so far just a noisey fan and a little antifreeze leak that I can't find yet.
Matt
Matt
#25
I had a similar problem on my 07 500X2. We were riding and all of a sudden it started missing, backfiring, and then stopped. It started again and then backfired every time I'd let off the throttle. It would cut in and out but I kept riding it for four days. I got home and checked everything. I found a loose ground from the battery. It was causing the ignition to cut in and out and screwing up the fuel injection.
#26
<div class="FTQUOTE"><begin quote>Originally posted by: melk54
I went down to my polaris dealer. He is also a Harley dealer so those pins was very regular as I understood. Think he says something about chevrolet used those in they plugs.
They was on a strip with pins on.
When you change these you need to remove the plastic cover in front of the plug, Now you will see a plastic tag(need light to see). Take a small thin object and bend this plastic tag and push out the pin.</end quote></div>
Melk, where is your Dealer located?
#27
been a while for the reply, sorry. Forgot about it till I needed the kit number today for the tbap sensor.
700/800 EFI Sportsman/Ranger
2875542 - TBAP
2875543 - Engine Temp
500 EFI Sportsman/ranger
2876315 Map sensor
2875900 Air Temp
2875901 Fuel injector
2875542 - TBAP
2876315 Map sensor
2875900 Air Temp
