Electrical light mod for small 4-wheelers
Old Sep 17, 2007 | 12:27 AM
JoeDirty's Avatar
Default Electrical light mod for small 4-wheelers
I have a 90 sportsman and a 50 scrambler for my son and daughter. Neither have working headlights and they very much want to have some for riding in low light.
I bought a cheap set of lights from ebay and installed them on the 90. They work great but maybe i have them wired wrong because after a couple of days of riding the battery is now drained and it will not start by electric starter.
Do these 4-wheelers have enough juice to run a small set of lights?
I wired the lights to the switch so that when the key is on, the lights are on. I plan to wire in a switch so that they can be turned off during day riding. Will this help or is there just simply not enough juice to keep the battery charged when they are on?
Thanks
Old Sep 17, 2007 | 07:08 PM
SCRAMMYTODD's Avatar
I would assume that there just isn't enough juice for lights on those little bikes. If you really need lights, put them on a switch so they are only on when needed. Maybe drop it down to one light per bike and see how that goes for you.
Old Sep 17, 2007 | 07:26 PM
twister500's Avatar
Not enough juice on the little machines for anything other than a small bulb. I have an E-ton 90 r viper and I put on the optional light kit and the bulbs are the little #194 bulbs that you use in the dash or side marker lights and they do not come on unless its running the stators on theese are small and cant handle anything else.
Old Sep 18, 2007 | 12:02 PM
JoeDirty's Avatar
Thanks for the replies.
This is what i was thinking also. I figure there just wasn't enough power to run the lights, but it looks cool on those little machines. I have already planned to wire in a switch so they can only use them when needed. And its not that they will be needing lights all that much anyway. I dont plan on doing much night riding with them. Its mostly that they wanted lights like Daddy's does [img]i/expressions/face-icon-small-smile.gif[/img]
skinnyr6
Aug 25, 2023 02:18 AM
Big bousse
Sep 26, 2015 10:42 AM
JohnnySplat
Aug 6, 2015 12:07 PM
mdigitale
Aug 6, 2015 12:35 AM
DeFox500
Jul 26, 2015 06:32 PM
