07 Sportsman 500 (2 questions)
1.
Went to check / clean air filter, and noticed an inch or 2 of what appeared to be old nasty oil at the bottom of the air cleaner box. I'm not using oil, and the owners manual doesn't have this in there. What is it?
2.
On top of my gas tank, from under the console, a 3 wire connector plug magically appeared. Nothing seems disconnected, and everything is fine. What's this wire harness for?
Thanks all!
2.
Thanks all!
<div class="FTQUOTE"><begin quote>Did you flip your quad?</end quote></div>
Actually yes, once, got it back up on all 4's within 15 seconds.
Sweet quad though.
FYI, those stock tires must be pretty soft. I had 7psi pressure in all tires (at 1200 ft. elevation), went camping at 7000 ft. elevation, and the ride was rough!
The tires automagically pressurized themselves to 8.5 psi.
I lowered them to 5.5 lbs, and the ride was awesome yet again.
Got back down to 1200 ft, low and behold, tires were now down to 4psi.
I'm assuming that the tires "pumped up", like a bag of chips driving up to the mountains.
Sweet quad though.
