400 Xplorer reverse limiter?
Old Sep 25, 2007 | 07:01 PM
97xplorer's Avatar
Default 400 Xplorer reverse limiter?
what is the reverse limiter and how can i adjust it? I was told to check that since my xplorer wont go in reverse very well.
Old Sep 25, 2007 | 07:06 PM
97xplorer's Avatar
and i was looking around on here and read that just hitting the OVERRIDE button (yellow) and it should go away and it does. But why do I have to hit the yellow button?
Old Sep 25, 2007 | 07:17 PM
hoytultratec's Avatar
hit the yellow button and give it gas it will go in reverse it is a saftey feature.
Old Sep 25, 2007 | 09:22 PM
97xplorer's Avatar
ok. but why is my reverse messed up?
Old Sep 25, 2007 | 10:08 PM
SCRAMMYTODD's Avatar
How about a little more infoon the reverse being "messed up" That could mean a lot of differant things. What exactly is it doing??
Old Sep 26, 2007 | 06:53 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the reverse override would have nothing to do w/ it going into reverse as its an override to make it go faster in reverse. when the button is pushed it allows you to go as fast backwards as forward(hence the safety) and also has to be pushed in to have the awd work in reverse.
Old Sep 27, 2007 | 08:12 PM
97xplorer's Avatar
like when I had it in reverse, it would sound like its going to back fire. but when I hit the override button, it works fine.
Old Sep 27, 2007 | 10:53 PM
ftwflh's Avatar
THat is the safety device that keeps you from going wide open in reverse and getting hurt
Old Sep 28, 2007 | 07:46 AM
97xplorer's Avatar
but i am just trying to back up.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
rockinkgin
Sep 25, 2015 01:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
