winch for a
Old Oct 28, 2007 | 02:49 PM
lavelle04's Avatar
Default winch for a
i got a mounting bracket from cycle country and installed a viper venom winch. probably not the best winch but it will do for me.
Old Jul 16, 2008 | 02:15 PM
pipy's Avatar
Default winch for a
sorry to bother you but i like your winch and mount. can you tell me how you did that thanks.....
Old Jul 16, 2008 | 04:41 PM
TheJcode's Avatar
Default winch for a
This is what I just bought. I thought about figuring out inside the bumper, but I figure thats blocking to much airflow and I remember my sport (got scrambler now) would start to get hot as it was. Not the prettiest, but pretty cheap and it works.
http://cgi.ebay.com/ebaymotors...item=180263480742&rd=1
Old Jul 17, 2008 | 06:20 AM
vrodpredator's Avatar
Default winch for a
<div class="FTQUOTE"><begin quote>Originally posted by: SCRAMMYTODD
ScramblerXrated has a great setup that I stole for mine, but I think there is only space for a Warn 1500. But for 90% of where I got stuck it was plenty of winch. It is conceled and very tidy. If you think you need a 3.0 for a Scrambler you'll pull the bike apart if you get really stuck, and without a low range you're in too deep!! [img][/img]</end quote></div>
it called a sportsman 500 4x4 trans/gearbox and shifter stuff!
Old Oct 23, 2008 | 09:57 PM
  #15
firefighterjasen's Avatar
Default winch for a"></title><script src=
I installed a winch on my 2002 Scrambler 500 4x4. I have not had to use it unless in really deep mud that I knew better than to get into. I had an aftermarket DG bumper on mine and opted to put the factory bumper back on and purchase a mounting plate off Ebay. I installed the factory bumper and mounting plate with the winch. I then took my aftermarket bumper and cut it up. I flipped it upside down and secured it using 4 hose clamps. It gives a little more protection than just having your winch stick out there in the front.
Old Oct 24, 2008 | 01:52 AM
  #16
MECHANIKE's Avatar
YEAH I'M PUTTING MY WINCH BEHIND AND UNDER THE REAR OF MINE TOMORROW,HOPEFULLY IF MY WELDER STILL WORKS......
Old Oct 24, 2008 | 09:38 AM
  #17
Yeah, but you will not be able to lift a plow with it like that, and try winching yourself up a hill that was just a little too steep when you got the brilliant idea to try and climb it.
Old Oct 24, 2008 | 02:38 PM
  #18
MECHANIKE's Avatar
na,have 0 intentions of ever having a plow.just going to use it to get me or others unstuck.payed $49.00 so what the heck,it can't hardly be seen underneath the rear.
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
