Horn on Sportsman?
Old May 29, 2008 | 03:19 PM
  #31
RticKwad's Avatar
Runs Stealth!
Default Horn on Sportsman?
I resurrected this thread cuz I went out last week to FINALLY add on my horn before
my weekend ride and when I started looking the HORN over, I just see the Negative (-)
and Positive (+) connectors and I don't see a place for separate connector for the wiring
of the switch? I suspect that I run my wires off the HORN to the respective battery (+ and -)
terminals. I have a fuse box to add in between for shorts etc. But where would I run the
wire for my switch to activate it (HONK. HONK) -- LOL? Unless the default in the Horn wiring is
to off and the switch will be in-between and when it detects the cross then it BLOWS??
Suggestions?
R'
Old May 29, 2008 | 05:24 PM
  #32
RandyL's Avatar
JUSt get one of these, then you won't have to worry about wiring it up.
http://www.youtube.com/watch?v...GCae94&feature=related
Old May 29, 2008 | 05:38 PM
  #33
HIGHOCTANE's Avatar
You need to put the switch in-line in either the negative or the positive wire...If you hook both wires up to the battery with no switch to break the circuit the horn will blow constantly. I would use the positive wire to put the switch in-line and run the ground to the frame close to the mounting location.
Old May 29, 2008 | 06:17 PM
  #34
Hawkman300's Avatar
if ure just gonna use it to signal someone if u get lost or something like that, just get a canned air horn, lol!
Old May 29, 2008 | 08:03 PM
  #35
user493's Avatar
Moto Psycho
Negative ground to the frame. Positive wire from battery to switch, and from switch to horn.
  #36
upnort's Avatar
Should run Batt + / fuse / switch / horn + / horn - to com i.e. frame.
Some horns are grounded through the horn frame so is only 1 terminal on the horn.
It is always good practice to add the fuse just in case the + wire gets worn through , horn shorts, wire comes loose etc.
Old May 29, 2008 | 10:31 PM
  #37
greeneiger's Avatar
I have a horn on my Eiger. Cost me $40 can. but my eiger was wired for it from stock.I've found it very handy but could be a little louder.
Old May 30, 2008 | 12:07 AM
  #38
RticKwad's Avatar
Runs Stealth!
Okay ya'll I think I got it now. Here is a little hack job of my diagram:
R'
Old May 30, 2008 | 01:30 AM
  #39
user493's Avatar
Moto Psycho
<div class="FTQUOTE"><begin quote>Originally posted by: RticKwad
[IMG][/IMG]
R'</end quote></div>
ooooookay
Old May 30, 2008 | 04:37 PM
  #40
RticKwad's Avatar
Runs Stealth!
See above! RE-EDIT!
R'
