Blue Smoke out the tailpipe
Old Nov 7, 2007 | 10:03 PM
ohnet's Avatar
Default Blue Smoke out the tailpipe
I premix on my 95' Scrambler and since I replaced the head gasket & plug, it's been blowing blue smoke out the tail pipe, more than it should. I'm using a 32/1 mix and I filled up the counterbalance after I replaced the gasket because it was low. I'm pretty sure it's got to be one of these two things, but I'm having a hard time determining which one. Any ideas?
Old Nov 7, 2007 | 10:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
how is the rings? did you do a compression test? the bluish smoke is from burning oil most of the time. check the plug to see if its oil soaked. if so then then the rings might getting bad. just an idear.
Old Nov 7, 2007 | 10:20 PM
ohnet's Avatar
It's got about 8 hours on the new sleevin', so I haven't bothered doing a compression test. The gasket blew either because the fan quit working because, #1 I had to fix that as soon as I got it running again, or #2 one of the helicoils in the jug didn't hold.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
