08 800 Missing / Bogging
Old Nov 17, 2007 | 08:24 AM
500DUSE's Avatar
Default 08 800 Missing / Bogging
I have the same problem on my 05 800.
Try useing a gas additive,seems to me they get a lot of condinsation in the gas tank.
I have to use it on every tank of gas ,otherwise it starts the sputtering.
I use seafoam,but heet should do the same.
Old Nov 19, 2007 | 07:07 AM
RolliePollieOllie's Avatar
Sorry I didn't get back to you's sooner on the diagnosis of this. A few days ago I went to start it and there was nothing. When I went to put the battery charger on it I noticed the ground connection was loose. Tightened it up and trouble free riding ever since. I am quessing was it got some vibration and shaking at the higher speeds the ground was loose enough to only ground intermittently. Runs like a charm now. One other question though. Has anyone found the oil drain plug extremely tight when they performed their first oil change? I twisted my allen wrench on it and then it slipped. I bought the socket drive style allen bit and I am hoping this is going to work. If the head gets stripped it is going to be ugly.
Old Nov 19, 2007 | 07:17 AM
500DUSE's Avatar
[img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 19, 2007 | 07:49 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
ya battery ends being loose will do it as it needs that 12 juice to even stay running right. yes they do tighten there bolts and plugs way too tight. thats why the correct size tool is the key for sure and no slippage will occure.
Old Nov 21, 2007 | 02:48 PM
  #15
encorebilly's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: RolliePollieOllie
Sorry I didn't get back to you's sooner on the diagnosis of this. A few days ago I went to start it and there was nothing. When I went to put the battery charger on it I noticed the ground connection was loose. Tightened it up and trouble free riding ever since. I am quessing was it got some vibration and shaking at the higher speeds the ground was loose enough to only ground intermittently. Runs like a charm now. One other question though. Has anyone found the oil drain plug extremely tight when they performed their first oil change? I twisted my allen wrench on it and then it slipped. I bought the socket drive style allen bit and I am hoping this is going to work. If the head gets stripped it is going to be ugly.</end quote></div>
I think the allen may be metric.As in 6mm.
Old Nov 22, 2007 | 10:11 AM
  #16
Kerbbirds's Avatar
It is metric, use a little valve lapping compound on your allen wrench it will keep it from slipping.
Old Nov 22, 2007 | 10:15 AM
  #17
Is this compound just something standard you can find at an autoparts store? Thanks for the tip
Old Nov 22, 2007 | 10:38 AM
  #18
stendori's Avatar
Super Quad Patrol
I'm watching you!
if theres room a impact driver works good to loosen them as well w/ a socket allen wrench.
Old Nov 24, 2007 | 02:07 AM
  #19
Williebee's Avatar
Yes you can get the valve grinding compound at any auto parts store , they have either clover or permatex brand's ; just tell the parts guy or gal that you want valve grinding compound for lapping the valves and they will know what you want !........
Old Nov 24, 2007 | 07:46 AM
  #20
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you haave the right size you shouldnt have to do any thing else to gett it off and if its a loose fit in the allen head dont use it as it might strip out so wht take a chance w/ the wrong tool. just my .02
95wolv
Sep 27, 2024 12:00 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
tysonbully
Sep 28, 2015 02:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
