Oil tank swap
Old Nov 12, 2007 | 07:45 PM
vig's Avatar
vig
Default Oil tank swap
okay guys My plastic oil tank is coming apart, it is spliting in two, and I dont want to replace it with another plastic one, Any one think that a metal one off, of an older machine will work on a 2005 sportsman 400? I cant belive they use plastic for this.
Old Nov 12, 2007 | 09:47 PM
itch's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: vig
Any one think that a metal one off, of an older machine will work on a 2005 sportsman 400? I cant belive they use plastic for this.</end quote></div>
as far as i know their all plastic
Old Nov 12, 2007 | 10:05 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I can't believe they don't make a aftermarket one yet!!!...........You can buy just about anything else!!!!!................I think later on down the road when more need to be replaced ..you will then see a market for a AL or metal tank!!!.....Caper..........
Old Nov 12, 2007 | 11:05 PM
chucks4x4's Avatar
I had to replace my plastic tank and it set me back $85. Plastic Junk
Old Nov 13, 2007 | 12:35 AM
Charlie's Avatar
It believe the aluminum tanks are still available through Polaris for around $74.00.
Its part # 5131255. In mid year 2002 they went to the plastic tanks.
I think the benefits of the aluminum would be better heat transfer for cooling with the metal and if it leaks you can reseal it because it is bolted together. Its definitly stronger. The mounting may be different.
The only benefits of the plastic is lighter weight and cheaper to make.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
