96 400 sportsman stuck in 3 wheel drive?
I was riding in the snow up a hill and noticed 3 wheels spining and not the 4th. It does this with awd button on or off? The front right wheel does not engage. I dont know much about awd and need a little advice on how to fix it. It pulls the steering the one way. Could it be frozon it has been cold here. Also could i disconect awd till i figure this out?
My 1996 Polaris 400 has the same exact problem thanks guys im trying it too. The only difference with mine is that it is in 3 wheel drive only when i turn awd on. Im hopin that the connection to the hub isnt broken, but ill try tranny fluid type
F first.
F first.
Do an ohmeter check on the hub wiring first. I believe you should have 23ohms resistance. I'd have to check the book at work to make sure and I won't be there till Wednesday! Woo hoo. Ok sorry. If you don't have that resistance and it is infinite resistance(open), check your wiring for a broken wire. If it's good, pull the hub apart and start inspecting. Make sure the armature plate is perfectly flat. No warpage. Check the hub coil face and make sure it isn't chewed up either. Loose wheel bearings can cause it too.
