Hawkeye mods for power?
Old Nov 25, 2007 | 09:00 PM
Hawkman300's Avatar
Default Hawkeye mods for power?
ya, those weights are what i meant. i guess there are different names for them. i know you can wheelie it if you get on your knees and lean back. i guess it cant do this stuff cuz its soo heavy for its size. 550 Ib is alot for that engine. is there any way to tune for more top end or more bottom end?
http://www.youtube.com/watch?v...qpEOgo&feature=related
this is what im talking about.
Old Nov 25, 2007 | 09:04 PM
Mongrol's Avatar
"Official Site Skeptic"
Nope, what u see is what you get.
Old Nov 25, 2007 | 10:10 PM
sheepdogMSP8117's Avatar
The maker of that video is our very own RickeyParker. If you search the terms Hawkeye and Clutch in the Polaris forum you'll probably find lots of posts on this topic. I believe you can also search by author and find all of Rickey's posts. He has tried out a lot of different stuff on the Hawkeye.
Old Nov 25, 2007 | 10:37 PM
hoytultratec's Avatar
i hust did a search and you can change roller weights on these this would help his quad on low end power should give it more jump off start.
do what sheepdog says and do the search seems ricky parker has some exp with the hawkeye.
Old Nov 25, 2007 | 10:40 PM
  #15
http://forums.atvconnection.co...word1=hawkeye%20clutch
Old Nov 25, 2007 | 10:47 PM
  #16
if you do this make sure if you take it in for service put the stock set up back in im thinking this could void warranty but it sure seems to work.
Old Nov 25, 2007 | 11:15 PM
  #17
Mongrol's Avatar
FACT; The Hawkeye stock is approx. 17 HP.
If you were lucky enough to modify it to a 10% improvement, you would now have approx. 18.7 HP.
FACT; Performance costs money.
How fast would you like to go?
FACT; As performance goes up, usually parts start giving in.
Check with Rickey P. He said in a post that he rides his Hawkeye aggressively and has hurt it on occasion.
FACT; The Hawkeye is an entry level quad and has had problems in the past with the frame mounting tabs in the rear breaking.
Good luck with your project.
Old Nov 25, 2007 | 11:36 PM
  #18
drop a couple of grams on the roller weights will probably help bottom end performance without wrecking stuff i would bet.
Old Nov 26, 2007 | 12:07 AM
  #19
Mongrol's Avatar
This is one of RickeyParkers posts along this line.
There isn't any balance problems with removing the two Opposing rollers, I've done it, as long as its balanced. Just a thought on a earlier post where the Polaris dealership got a Hawkeye up to 63 Mph. They added even heavier rollers than the 14 gram rollers and re-jetted and fixed that awful muffler that came on the o6 models with the 3/4 inlet and outlet. I put the calculator to it and if a person were to have 11.5 gram rollers and jetted it right,. The only word of advice is to use LOCTITE red on the nut when you put it back together or that nut will spin back off when it kicks back from deceleration. I've tried both ways with the rollers and its where the performance loss is. With those heavy rollers and if you put bigger tires on it, then you really need the 12 gram or lighter rollers or just remove 2 rollers and be happy. Use LOCTITE OR YOU WILL GET STRANDED with a very high revving slow moving quad.
Before you rejetl read my post marked TUNING.
Old Nov 26, 2007 | 12:16 AM
  #20
i wouldnt be afraid to do it if it was mine in the world of china quads (i own 2) guys do it all the time because there are no real mod part available and have definite improvements i guess they got the idea from all them little buggies out in the dessert i read about on i think the site was buggies.com and it helped them things alot, like i said its a thought i have no idea i never did it to the one i have. but i feel if you dont go to extreme it wont hurt the machine and 30 bucks is a cheap mod.
Cole Hadden
Jun 15, 2025 09:05 AM
ElementzzofStyle
Aug 29, 2015 10:45 AM
ElementzzofStyle
Aug 27, 2015 12:54 PM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Sportsman850
Jul 31, 2015 04:25 PM
