lights and diplay went out
I have speedo display problems now but had aproblem like yours before and the schematic looks like it might be engine stop switch related. mine was just barely off and caused just about the same thing. a few minutes later it died and i noticed the swith and back in buisiness.
check all connection for corrosion and put some dilelectric grease in then. make sure there isnt a bad relay somewhere as well. if you are loosing all electrical then its possiable thatthe switch or kill switch is messing up but it should make the bike quit as well.
#15
well I went through all my wiring and greased up all the connections. battery wires were a little loose so I'm hoping that was it. I'm gonna ride it around a little tommorrow and see what happens. I believe it was the battery cables. thanks guys. I will report back if that was it.
