'94 425 magnum won't start, please help.
Well I finally found some time to work on this Polaris, here's an update.
Found that there was a bad fuel line, replaced all fuel lines, and fuel filter. I am once again running but,...... There's always a But! It runs great at idle! When you try to give more than half throttle, it starts back firing, and chugging and can't get past the half way point. Will run at a smooth idle all day long!
So any suggestions? I've run carb cleaner in the fuel and sprayed some in the carb, still same results. It's always the same 1/2 throttle and it puke's.
Thanks for any input.
#17
Well, that took care of the running under load problem. But, now the low idle is running a bit rough, sounds like diesel engine. I've adjusted the idle screw can't find a happy medium either chugs or runs fast. I've not messed with the air mixture valve. Could that be a possibility?
02Chevrolet
1) Engine problems..
06-23-2015 12:12 AM
