05 sportsman efi "missing"
Old Dec 19, 2007 | 12:07 AM
GoingVirtical's Avatar
Default 05 sportsman efi "missing"
Haven't been here for a while, need support. It seems when the coil gets wet under the left front, it will start missing running on 1 cylinder. I reach under and wiggle it, runs fine agian. I removed it, cleaned the grounding area, but still have issues every now and then. Any suggestions. You would think if the ground was bad, I would loose both cylinders.
Thanks in advance for any help
Old Dec 19, 2007 | 02:02 AM
RickCJ7's Avatar
Replace the coil!
Old Dec 19, 2007 | 06:18 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
im surprised only one cclinder goes out when it gets wet for it to be a bad coil?
Old Dec 19, 2007 | 06:39 PM
Here is what I found. On the belt side of the machine, the spark plug wire was white and arcing to the motor. This is the second time it's happened. It's just above the point where it seals the mud oud out of the hole, right in the thickest part of the rubber. Has this ever happened to any of you??
Jmuddin284
Jan 19, 2026 07:16 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Big bousse
Sep 26, 2015 10:42 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sportsman850
Jul 31, 2015 04:25 PM
