new to the forums... need help
Old Dec 23, 2007 | 04:10 PM
trail hog's Avatar
Default new to the forums... need help
Hi all, I'm new to the forums, but a long time rider. Started out in the 70's on dirt bikes onto three wheelers, and now riding quads since I bought a '87 Worrier. I now ride a '98 sportsman 500 and I need help. I changed the battery about two weeks ago. It ran fine for a while and now no spark to the plug. Everything else works fine, lights, turns over fine, just no spark to the plug. I pulled off the cover under the headlight and found two broken wires. Fixed those and still nothing. Help a storm is on the way.
Old Dec 23, 2007 | 04:59 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Key switch and or Red engine kill switch would be a good place to start...........They both will not give you spark if they are faulty!!!.......Caper.............
Old Dec 23, 2007 | 05:07 PM
trail hog's Avatar
Thanks Caper.....
Any ideas on how to bypass the two swithces to check them out? .....Don
Old Dec 23, 2007 | 05:14 PM
I would check first to see if they are clean ...........I mean no bad connections............This can be done with a multi-meter set to the ohms scale and check each position on the switch...........This will tell you if the are making contact(continuity) between the different positions...........Caper...............
Old Dec 23, 2007 | 05:16 PM
trail hog's Avatar
I'll give a try...thanks for the help....Don
Old Dec 23, 2007 | 05:52 PM
ftwflh's Avatar
try a new plug
Old Dec 23, 2007 | 05:54 PM
trail hog's Avatar
I did and still no spark.
Old Dec 23, 2007 | 05:58 PM
sblue's Avatar
Did u try a new plug wire?? Just thinking.
Old Dec 23, 2007 | 06:01 PM
trail hog's Avatar
Need to tear the machine apart to get a good look. That's next.....Thanks
ftwflh's Avatar
Check the throttle play on the ETC
J-ROD
Apr 5, 2011 11:58 AM
535cheetah
Jun 25, 2010 02:00 PM
Hebs
Utility ATVs
16
Jan 24, 2007 10:35 PM
FatHolly
Jun 25, 2006 08:17 AM
bur252
Utility ATVs
Jun 19, 2006 02:00 PM
