Trail Boss 325 info??
Old Dec 23, 2007 | 04:37 PM
GCOZMO's Avatar
Default Trail Boss 325 info??
I just joined up. About a month ago I bought a 2000 Trail Boss 325, great little machine. Took all the plastic off today and cleaned it up really good. I have never seen so many grease fittings on one machine in my life !! Does anyone have one of these that can give me a little insight on things to look for?? Thanks Greg
Old Dec 23, 2007 | 05:56 PM
ftwflh's Avatar
Change the oils and keep ALL the grease fitting greased along with keeping the chain adjusted right.USE ALL Polaris fluids to be safe.Check the axle bearings for play,swingarm bushings for play,tie rod ends,ball joints,wheel bearngs and brakes.Replce the bad stuff and you will have a good machine for years.
Old Dec 23, 2007 | 07:50 PM
hoytultratec's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ftwflh
Change the oils and keep ALL the grease fitting greased along with keeping the chain adjusted right.USE ALL Polaris fluids to be safe.Check the axle bearings for play,swingarm bushings for play,tie rod ends,ball joints,wheel bearngs and brakes.Replce the bad stuff and you will have a good machine for years.</end quote></div>
what he said...i have done all that to mine and for dumb reason i love this this old polaris.
Old Dec 23, 2007 | 11:05 PM
GCOZMO's Avatar
Thanks for the input. I purchased the upgraded outer tie-rod ends this week. The old ones had a little too much play for me. I bought them from the local dealer but I think I will order them online next time. I found a place called Babbitt's that seems to have pretty good prices. Any suggestions on suppliers?? Thanks again, Greg
Old Dec 23, 2007 | 11:10 PM
bikebandit.com or just google polaris parts should find a bunch.
Old Dec 23, 2007 | 11:11 PM
ftwflh's Avatar
Check with Snow Polaris in PA
Shainasmash
May 8, 2017 06:38 PM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
