hand and thumb warmer
Old Dec 28, 2007 | 10:16 AM
flipperz71's Avatar
Default hand and thumb warmer
Thanks everyone for the advice. I will tackle the install on Sunday, and should get to try them out Monday and Tuesday with some fresh snow...
Hope everyone has a Great New Year....
flip
Old Dec 28, 2007 | 06:37 PM
SpudRacer's Avatar
I did the Pure Polaris Handgrip warmers and thumb warmers myself as well. The Air Compressor trick works as advertised. Just put a finger over the small hole on one grip, and put the air nozzle against the other small hole. I got the first one off with only 30psi. I then used my hand to cover the bar end, and reapplied the air chuck to the same small hole, and off came the second grip.
As for the switch, I used the one that came with the kit, and wired both the handgrips and thumb warmer to the same switch so I wouldn't have to install two switches on the dash. I mounted the switch to the right of the Speedo. The thumb warmer on high can cook an egg and (at least on my 800EFI) gets much hotter than the grips. I use high when riding to get the grips and thumb hot, then switch to low so neither gets too hot. A little dishsoap and the stock grips slide right back on, but don't take your time or they get hard to slide on pretty quickly.
Tom
Bryson City, NC
Old Dec 28, 2007 | 07:47 PM
smooth1's Avatar
Thanks for the tips SpudRacer....... i will be installing mine sometime next week...........smooth
Old Dec 28, 2007 | 09:37 PM
tcihla79's Avatar
i put mine on last weekend and got to try them today and on low i couldn't hardly feel them, if at all. high was warm but not overly hot. guess i need to pull the pod check the switches???
Old Dec 29, 2007 | 03:40 AM
  #15
SpudRacer's Avatar
I'm getting the power for mine from an auxillary fuse box I installed from Painless Wiring, so I may be getting more power then tapping into an existing circuit. Just a thought.
Tom
Bryson City, NC
Old Dec 29, 2007 | 08:12 AM
  #16
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: tcihla79
i put mine on last weekend and got to try them today and on low i couldn't hardly feel them, if at all. high was warm but not overly hot. guess i need to pull the pod check the switches???</end quote></div>
I installed the Hot Grips on mine and the grips get very hot, enough to be uncomfortable without gloves on. I thought about wiring both to the same switch but was told some wire parrel and some wire in series and might not get the correct amount of power.
Old Dec 31, 2007 | 07:59 PM
  #17
flipperz71's Avatar
Went to the local electronic shop today to pick up 2 illuminated rocker switches. They did not have any nor could they order them... I would prefer to install the lighted rocker switches vs. wiring in an LED with the switch. Does anyone know where I can get these online?
Thanks
HAPPY NEW YEAR..
flip
Hack714
Sep 26, 2015 08:11 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
Hack714
Sep 20, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
