hand and thumb warmer
Old Dec 26, 2007 | 02:06 PM
flipperz71's Avatar
Default hand and thumb warmer
Got a set of PURE handwarmers and a thumbwarmer for my 06 700 twin. Any suggestions when going to install these? The only upgrade I can see happening is an illuminated switch to visually see if they are on or off. The post toggle switch looks a little cheap...
Happy Holidays...
Flip
Old Dec 26, 2007 | 09:54 PM
sandman13's Avatar
Installed mine in about an hour! Yes the switches are going to get changed to a illuminated switch... I fired up the air compressor and popped the grips off!!!!
Old Dec 26, 2007 | 10:26 PM
tcihla79's Avatar
put mine on saturday. bring on the snow and cold. wish i would of thought about the compressed air trick
Old Dec 27, 2007 | 08:17 AM
flipperz71's Avatar
Is it a good idea to wire both the grips and thumb on the same switch or should they be seperated?
Old Dec 27, 2007 | 09:18 AM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: flipperz71
Is it a good idea to wire both the grips and thumb on the same switch or should they be seperated?</end quote></div>
Seperate! you'll probally run grips on low and thumb warmer on high.
Old Dec 27, 2007 | 10:01 AM
flipperz71's Avatar
Last question... I promise....
Where is the best place to mount the switches. I would like them easily accessable but not in the way that I would accidentally hit them.
Do I need to buy new grips? or can I reuse the factory one. I see someone posted a reply about using an aircompressor to pop the old ones off???
thanks
flip
Old Dec 27, 2007 | 05:14 PM
sandman13's Avatar
I used the air to get them off so I could reuse the grips... I mounted the switches, one on each side of the spedo.. they are out of the way there for me! It's the best upgrade I did so far!!!!!
Old Dec 27, 2007 | 08:31 PM
smooth1's Avatar
just seen this thread......how do you use the air compressor to remove the grips........smooth
Old Dec 27, 2007 | 08:46 PM
sandman13's Avatar
using the blow gun, stick it in one side of the handbars, you need to cover the other side with your hand/finger and one or both should pop off. I ended up shoving a rag into the side the grip came off to help seal it to get the other one off. I used the air to reinstall the grips all the way back on!
Old Dec 28, 2007 | 10:05 AM
smooth1's Avatar
Thanks for the tip, I will try it when I put my hand warmers on.........thx.......smooth
