Polaris Angle Drive Fluid?
Old Dec 30, 2007 | 11:24 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default Polaris Angle Drive Fluid?
Well I was looking through my Polaris Factory Service Manual (too much time off work over the break)..Anyway I have both listed in the chart under Gearcase/Transmission Lubricants........................................ .But in the proceedure It tells me to use Polaris Premium Demand Drive Hub Fluid Part # 2871654 CAP=(5.0 oz.(150ml)......Which I use!!
But my question here is Where is the Polaris Angle drive fluid used and in what year/models...Did they change in 2005?........I looked through manual and didn't see anywhere that this was listed.......Was this used right at the hubs?(wheels) Before the center Gearcase was used!!....If so why is this listed in my 2005/2006 service manual?.........Thanks........Caper.........
Old Dec 30, 2007 | 11:33 AM
SCRAMMYTODD's Avatar
Angle drive fluid was for the front diffs on the bikes that engaged in the wheel hubs. It is 80W90 gear lube from what I've read. It's listed in my 07 somewhere as well.
Old Dec 30, 2007 | 11:38 AM
Why would Polaris list this in my Service Manual?...............or even in your as well.
I don't need to know that infomation for my year and model.
Oh well I hope people will read there Service manual in detail before they go out and buy the Polaris fluids listed in the chart.............SOME YOU DON"T NEED!!!!....LOL......Caper.........
Old Dec 30, 2007 | 11:41 AM
<div class="FTQUOTE"><begin quote>Originally posted by: SCRAMMYTODD
Angle drive fluid was for the front diffs on the bikes that engaged in the wheel hubs. It is 80W90 gear lube from what I've read. It's listed in my 07 somewhere as well.</end quote></div>
It's listed in your 07 owners manual or Service manual?
I thought you never had a Service manual.
...Caper.....
Old Dec 30, 2007 | 11:48 AM
Just read something else now in my Owners Manual!!...Not Service manual like above,
Rear gearcase for the Sportsman 700 (2006) it says to use the Angle Drive Fluid (or GL5--80-90 weight gear lube)........My service manual does not cover the Sportsman 700 for 2006 ........Confused yet?.....LOL....................Caper............. ...
Old Dec 30, 2007 | 11:52 AM
sheepdogMSP8117's Avatar
The Angle Drive Fluid is used in the Twin's rearmost gear case.
Old Dec 30, 2007 | 11:53 AM
Just an owners manual for me. You must be on shut-down with all this reading you're doing LOL
Old Dec 30, 2007 | 11:57 AM
Yeh.................Maybe I will read the phone book next!!!!.....LOL....LOL.....Caper..............
Old Dec 30, 2007 | 12:44 PM
RickCJ7's Avatar
older models
front hubs = premium hub fluid
front gearcase= angle drive fluid
trans= AGL
rear gearcase=AGL
newer models
no front hubs
front gearcase without ADC= premium hub fluid or new LT fluid
front gearcase with ADC= LT fluid only
trans= AGL
rear gearcase= AGL
simple??
I read some oil posts on other forums about all the confusion, a 4wd pick up takes 4-5 differant oils! not counting brake,power steering, ADC fluid etc........
Front diff
engine
trans
transfer
rear diff
I only need 3 oils for my X2
Old Dec 30, 2007 | 12:53 PM
Simple ,yes............But why is that Angle fluid listed in my 2005/2006 Sportsman 400/450/500 Service manual? When none of the models it covers needs that type?.......That's all I was asking.........Caper........
