Shutter in drive line
Old Jan 7, 2008 | 09:10 PM
1959dry's Avatar
Default Shutter in drive line
I have a 1997 Explorer 500 that has developed a shutter in its drive. Better said is the belt is slapping around after I take off. It only does it once after takeoff then goes away untill you stop and go again. I have replaced both clutches and the belt but it still has the shutter after take off. Any Ideas?
Old Jan 7, 2008 | 09:16 PM
drlang's Avatar
Hi, lo and reverse? Doc
Old Jan 7, 2008 | 09:18 PM
1959dry's Avatar
SEEMS TO HAVE IN ALL THREE, WORST IN HIGH
Old Jan 7, 2008 | 10:02 PM
upnort's Avatar
Maybe put it up on stands & run with with clutch cover off & see if can't zero in on it.
Old Jan 7, 2008 | 10:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like it might be in the tranny if you have replaced belt and clutches.
Old Jan 7, 2008 | 11:30 PM
drlang's Avatar
Does that machine have ebs? Do you have the correct belt for that? Doc
Old Jan 8, 2008 | 01:19 PM
02magnum500's Avatar
Gets his share of deer.
How about motor mounts? Check them over.
Old Jan 8, 2008 | 04:11 PM
Hotdogmb's Avatar
Check the alignment of the clutches. Motor mount was a good guestion too.
Old Jan 8, 2008 | 08:47 PM
sassee's Avatar
ditto on checking the alignment! I had a bad low-end shudder on my sons TrailBoss. I had rebuilt the tranny and forgot to replace the shims behind the secondary clutch when re-assembling the ATV. I just got thru with putting the shims back on and the shudder is gone! (belt still slips like crazy, but that is about to be replaced))
Old Jan 9, 2008 | 06:25 PM
1959dry's Avatar
Thanks for all replies, First it is not an ebs clutch, I have had the belt cover off and you can see that at a certain point when increasing rpms it seems as though there is slack in the belt because it jumps around alot. It is a new belt purchased from my polaris dealer so I assume it is the right one, but my old belt was doing the same thing before I changed it. You may be on to something with the motor mount bolts, I will check them next. This is the reason I changed the clutches and belt because it developed this shutter, but it still is doing the same thing so I will keep trying till I find the problem. Thanks DRY
Ronk407NY
Feb 13, 2016 11:05 AM
ronnierhino06
Nov 9, 2015 12:56 PM
gamer17
Aug 15, 2015 12:38 PM
cody500ho
14
Aug 14, 2015 05:03 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
