bad noise from clutches?
Old Jan 10, 2008 | 09:31 PM
sassee's Avatar
Default bad noise from clutches?
OK..............................
I dumped the other thread and started over. I just put a new belt on the TrailBoss and the difference in performance is dramatic. But now I still have a noise that just started the over day that sounds like it's coming from one of the clutches. It only makes the noise under load, when I gun it. It does not do it when I start off slowly and it does not make the noise when I have the rear end up on a floor jack with it in gear from a little gas to wide open. The noise is kinda like a loose chain jumpin around on a sprocket??? (but it's not the chain in the tranny, it's new!)
Any suggestions?
Ernie
Old Jan 10, 2008 | 10:29 PM
drlang's Avatar
Well how are your chain and sprockets?
Old Jan 11, 2008 | 07:46 AM
sassee's Avatar
Chain and sprockets are brand new. That may have been a bad analogy, but I don't recall ever hearing a noise particularly like this before. The noise is definitely from sprockets and only when under a load. (when I take off quick) If i ease off, no noise and it will not make the noise at all with the rear up on jackstands.
e
Uhhh.............................Doc, you did say 'clutch problem" when I first posted with perfomance/noise problems last week. You may have been right from the start. Any other thoughts???
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
