replace ball joint
Old Jan 12, 2008 | 06:49 PM
sbishop664's Avatar
Default replace ball joint
Hi Guys, just wondering what's the easiest way to replace a ball joint? i was putting the arm back in and I can't tighten the ball joint nut, it just turns.
Was wondering how do you change a ball joint on a 96 xplorer 400?
i doudt they have ever been change, i've had the bike since 99. I should change the other side too?
thanks for any help
Sbishop
Old Jan 12, 2008 | 09:07 PM
badmoose's Avatar
Sometimes the nut will not tighten up, it does not mean your ball joint is wore out. True it could be wore out it is hard to say with out seeing it. To get the nut to tighten up you need to push up on the A-arm towards the bottom of the strut, say with a pry bar between the ground and the A-arm should give you the leverage you need. While prying upwards try to tighten the nut it should tighten up. Try this and let us know how it works out.
Old Jan 12, 2008 | 09:16 PM
sbishop664's Avatar
badmoose, i'll try that in the morning....cause I don't think it's bad..just can't tighten it up. i didn't have any play in it before I took it off and it came off pretty easy. thanks
Old Jan 13, 2008 | 10:16 AM
sbishop664's Avatar
Moose, thanks a lot, worked like a charmed, she is back up and going!
Old Jan 13, 2008 | 08:33 PM
badmoose's Avatar
I have seen ball joints on cars and trucks do the same thing. Usually I will clean the threads off with a rag and spray a little wd-40 on the threads before putting the ball joint back into the a-arm and tighting the nut Still some times have to do the pry up on it method.
Good news is you are up and rolling.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Dec 15, 2015 03:59 AM
toonces
Jul 28, 2015 01:58 PM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
