Warn 4.0 on Sportsman?
Old Jan 15, 2008 | 12:34 PM
SpudRacer's Avatar
Default Warn 4.0 on Sportsman?
Is it possible to stuff a Warn RT40 winch onto an 800 Sportsman? I know the mounting pattern is bigger for the 40, and it is for UTVs, not ATVs.
The reason is that my Warn 3.0ci winch holds 50' of 3/16 cable, and I need a slightly longer cable. I considered using an extension cable and a pair of parallel gripping pliers, but a longer cable would be so much easier to use. The RT40 has 55' of 7/32" cable which should be enough, or I could put 3/16" cable on it which would probably give me well over 60' of cable.
Tom
Bryson City, NC
Old Jan 15, 2008 | 12:54 PM
Sunset Ed's Avatar
Could you mount it on the hitch on the rear?
Old Jan 15, 2008 | 02:24 PM
brutus450's Avatar
couldnt you just use a 10ft or longer web strap as an extension?
Old Jan 15, 2008 | 03:04 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would try a longer cable or strap w/ you before i would try to put a 4.0 winch in which i guess wouldnt even fit
Old Jan 15, 2008 | 03:09 PM
SpudRacer's Avatar
Already using two tree straps, I just need about 5 more feet...
Tom
Bryson City, NC
Old Jan 15, 2008 | 03:56 PM
SCRAMMYTODD's Avatar
I would suggest getting stuck closer to the trees [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 15, 2008 | 04:19 PM
Blacksheep5's Avatar
what are you doing that you need such a long cable all the time?
Old Jan 15, 2008 | 08:08 PM
SpudRacer's Avatar
I'm using the Polaris to clear some property I own, but to get the Polaris up to the property (mountain property) I have to winch it up a 40 degree incline for around 60 feet. Once I get a driveway in, end of issue.
Tom
Bryson City, NC
Old Jan 15, 2008 | 08:53 PM
oh, well I guess that makes sense.
Cole Hadden
Jun 15, 2025 09:05 AM
toonces
Oct 19, 2015 02:21 AM
Erick J. Edler
Sep 20, 2015 05:51 PM
Gtsordo
Jul 22, 2015 01:27 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
