300 2x4 auto bootstrap operation
Old Jan 22, 2008 | 04:09 PM
Hotdogmb's Avatar
Default 300 2x4 auto bootstrap operation
take the carb off and clean it too.
Old Jan 22, 2008 | 07:05 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Hotdogmb
take the carb off and clean it too.</end quote></div>
You will need to take the jets out to be sure they are clean
Old Feb 1, 2008 | 02:00 PM
S0L's Avatar
S0L
Update- new gas, airfilter, gasfilter. Got it started two days out of the past ten. When it runs, it runs good, plenty of torque, a real blast. When it won't start, makes for a bummer day. Cause of no-start is when outside temp. is below fifty degrees. Prev. owner says remove carb (to clean) takes "half a day" and doesn't want to help with that. If anyone not have any other ideas, I'll have to find a manual and do it myself. Many thanks.
Old Feb 1, 2008 | 06:58 PM
S0L's Avatar
S0L
Forgot to mention:
* New spark plug
* Old fuel (pbly. 2 gal.) not drained. New fuel (2 gal.) poured in over old fuel.
Old Feb 4, 2008 | 10:23 AM
  #15
Hotdogmb's Avatar
Old fuel will do it every time. Drain the tank completly and fill with fresh fuel. You could add some fuel treatment as well.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Clint Russell
Sep 25, 2015 03:20 PM
Jason Poulin
Sep 20, 2015 02:49 AM
Alex G.
Sep 19, 2015 06:34 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
