Front diff input shaft seal (leak)
Old Feb 8, 2008 | 09:58 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Front diff input shaft seal (leak)
thats a good question. wonder if the leak you see is that fluid or the front end fluid. ill have to make sure i check mine this spring real carefully. make sure get the right fluid made for the adc and replace it before it gets air bound if it can. not sure if it can or not.
Old Feb 8, 2008 | 04:24 PM
quad 4's Avatar
Mine was on my observation. The day after I bought my X2 I expected all. I change myself the front fluid to be sure there was the right fluid. So I change it for the LT FLUID. I notice there was a leak at the same place as sheepdogMSP8117. Just a little leak. I clean it and none come off since.....but it was on my observation. I know HILLIARD don't said the same amount of fluid as POLARIS said for the front diff. Maybe there to much pressure in there????
Old Feb 8, 2008 | 08:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what did hillard recommend for amount, and did they get asked about the adc lt fluid vs the regual type? would be good to know from there point of veiw.
Old Feb 9, 2008 | 12:13 AM
Indslpwr04's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: sheepdogMSP8117
The parts guy was nice enough to print out the whole section of the manual for me to take home. They may be idiots, but at least they're nice.
S.</end quote></div>
When i red that I almost fell out of the chair LMAO.
What was the month of manufacture when the ADC started showing up on the SPMN. Mine is an 07 and it does not have it?
Old Feb 9, 2008 | 01:20 AM
  #15
SCRAMMYTODD's Avatar
ADC came out with the 07 SP Deluxe models and I think is standard on the 08s
Old Feb 10, 2008 | 11:44 PM
  #16
quad 4's Avatar
stendori....
On the HILLIARD spec....they said 5 oz for the front diff. POLARIS said 9.3 oz for the diff with ADC and 9 oz for standard diff on my 2007 x2 owner book. So who got the good one....I think....but is my guess, there could be pressure build up but is just my guess.....I don't know why POLARIS don't stick with the HILLIARD spec ????
Old Feb 10, 2008 | 11:52 PM
  #17
Theoretically there shouldn't be pressure build-up unless your vent is plugged. Just a thought
Old Feb 11, 2008 | 12:26 AM
  #18
quad 4's Avatar
I can't understand on this one...4.3 oz of difference....I think is a LOT. Maybe POLARIS was just simplify the way we fill the diff and fill it up flush to the tread was the best bet for all. Who know.
Old Feb 11, 2008 | 01:50 AM
  #19
sheepdogMSP8117's Avatar
My front differential didn't even take 8 ounces before coming to the bottom of the threads. As far as the difference in capacities, the ADC front differential has more room inside to account for two clutch packs and ADC pump cam plate and armature plate that is absent on the non-ADC front diff. That's what I figure anyway.
Old Feb 20, 2008 | 08:38 PM
  #20
The seal kit just came in today. Its an actual parts kit from Hilliard Corp. I hope to do this project in the next couple of days and will post pics and such.
