lower steering bushing
Old Jan 12, 2001 | 10:22 PM
gordo37's Avatar
just bought a HPD lower bushing.. my question is do I have to install the washers and rubber seal on the bottom of steering shaft before the castle nut and do you install the rubber seal before the steel washers
Old Jan 12, 2001 | 10:42 PM
HORider's Avatar
Hi Gordo, yes, put the shaft through the new bushing, then put on the seal, then both steel washers, then the castle nut and cotter pin. And take a few minutes to clean off any old grease from all the parts, and coat them with fresh wheel bearing grease before reinstalling them.
HTH,
Dave
Old Jan 12, 2001 | 10:53 PM
gordo37's Avatar
HORider thanks neighbor Being the second owner on the quad and I replacing plastic bushing with the hpd aluminum one it didnt make sense having the steel washers going on first then the rubber one... THANKS ALOT
Old Jan 12, 2001 | 11:01 PM
HORider's Avatar
Your welcome. I just installed the same bushing on a friends quad the other day. You made the right choice by purchasing what you did, and not another stock polaris bushing.
Ride safe,
Dave
Old Jan 12, 2001 | 11:11 PM
gordo37's Avatar
Any suggestions on how to replace rear sprocket. The one on the axle looks easy it is the one coming of the transmision......or should I just by the manual?
Old Jan 12, 2001 | 11:23 PM
HORider's Avatar
I dont really know. What machine are you working on? I would think that if you could change the rear sprocket, you could change the front sprocket also without a manual. Take your time, and think things through, you can figure it out.
Dave
Old Jan 12, 2001 | 11:46 PM
gordo37's Avatar
HORider it is a 95 scrambler 400 4x4 the motor is complete out and at the machine shop so in the mean time i am replacing parts in the process a-arm bushings done steering bushing done now for the chain and sprockets. Iam concerned about the sprocket coming of the transmision any suggestions on how to replace
Old Jan 13, 2001 | 10:24 AM
TheQuadfather's Avatar
When you install the HPD bushing, do not use the plastic washer. It will wear out,fall off, and cause your steering post to have about 1/2" play up and down. Instead, go to a hardware store and get a stainless steel washer of the same size, and use it. This has happened to three of my friends, including me.
exmotocrosser
Sep 13, 2019 06:12 AM
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
