Sportsman 500 Fuel Problem
#21
I pulled the carb and cleaned it out completely. I think you are right about the diaphram but I couldn't find a hole or tear in it. The reason I think that is the problem is because if I blow into the vent tube on the carb, depending on the amount of trottle I give it, it will run fine. But soon as I quit blowing onto it, it wants to die. What do you think?
#22
Pull the airbox lid off, pull the rubber gasket out, and replace the airbox lid (thus allowing a bit more air into the airbox on acceleration).
See if this helps (not the solution, however a good troubleshooting step)
If this helps, then you may have jetting issues.
#23
There is one thing I thought was odd about the diaphram, and that is it was kind of like it was streached like a ballon when it's been deflated. I don't know what it's suppose to look like, most diaphrams I have seen look like and automatic sprinkler valve. Anyway I guess I will order a new one tommorrow. Thanks again for the suggestions. I will let you know how it goes.
#28
a long shot, but what about a vaccume issue. not enough. maybe the line is messed up maybe crank vent is plugged. just a thought. also make sure its getting plenty of gas and theres not a bad petcock like someone else just found to be his issue from lack of fuel.
#29
The diaphram shouldn't look like a stretched balloon, if so, there is probably too much stretch in the rubber that it won't pull the slide up quickly enough or far enough. Maybe a picture or two of the diaphram (in the carb with top off and out of the carb) would help me diagnose it and give you further tips. I worked on and tuned 40mm CV carbs for a few years back when I had a Harley, and got fairly efficient with them.
skittero
35
Mar 1, 2019 12:39 AM
