1999 polaris xplorer wont start
Old Jan 27, 2008 | 11:33 PM
timreardon's Avatar
Default 1999 polaris xplorer wont start
i have posted before on this topic i have a 1999 polaris 4x4 explorer 400 that wont start by switch but willl start when pull started i have changed with a new battery all i hear is a clicking when i hit the switch but nothing happens, i heard the same sound with the old battery so i think the old battery was stiil good, any way any one know what i can do or check and how to check what ever i need to check, any help would be appriated
Old Jan 28, 2008 | 03:58 PM
dwhst9's Avatar
Starter solenoid.
Old Jan 28, 2008 | 06:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
w/ the key on try taking a heavy wire and jumping the 2 big solnoide bolts w/ the cables on. if it turns over the starter then the solnoide is bad if not chances are the starter is bad.
Old Jan 28, 2008 | 06:31 PM
ForestTrails's Avatar
Before you replace anything do some troubleshooting first.
First try watching the headlights when pressing the starter button. If they get very dim or go out when you try to crank then the battery is weak.
Check for loose connections at all the cable ends.
Try jumping the large studs on the selinoide to see if it cranks. If it does than it is the selinoide.
If it dos not, then check for voltage at the starter, If you have voltage at the starter when you press the button then it is most likely the brushess in the starter are frozen in place with rust. (It happens a lot with mine...) rebuild the starter. kits are available very reasonable on E-Bay.
Good Luck.
Remember the pull start is really a backup starting method so you don't get totaly stranded if your battery goes dead. I would hate to be out on a long ride and pull the string and have it break, leaving me stranded.
Old Jan 30, 2008 | 01:50 AM
wizard1212's Avatar
Odds are the the solenoid is not getting the juice that it needs, I had the same problem. Make sure that the solenoid is getting the power from the battery.
Old Jan 30, 2008 | 09:43 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you test this yet? i would not buy anything or take it apart until you do some checking for sure first.
cornermike
Jun 3, 2015 07:27 AM
cornermike
May 27, 2015 10:04 PM
1000gade
May 27, 2015 12:37 PM
rsoxfan
May 30, 2000 12:23 AM
rsoxfan
May 28, 2000 03:27 AM
