Charging system issues.
Old Sep 22, 2011 | 03:35 PM
  #31
kincaidk's Avatar
Hello my name is Kenny and i have a problem with my 2001 polaris 500 sportsman Ho, i bought a new voltage regulator and battery and i still don't get but 12 volts showing on my meter when it is running. The voltage is dropping slowly. Can anyone tell me what i need to check now to fix this and get 14 volts? Thanks everyone, Kenny
Old Sep 22, 2011 | 04:36 PM
  #32
Recheck the connections on the regulator/rectifier,plus check the main harness coming up(on the right side) for the yellow,yellow/red and red wires that tie in(one could have come loose) Also just check with a test light to see if the red wire coming into the reg/rectifier has 12 volts while running.If all this checks out,head back to the battery connections,make sure they are tight. If they are ok,then either stator problem or battery. OPT
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
fredrikrosen
Sep 28, 2015 09:58 PM
