2000 Scrambler clutch engagement RPM?
Old 02-10-2008, 02:59 AM
Scrambalicious's Avatar
Default 2000 Scrambler clutch engagement RPM?
I'm poppin my cherry! I recently bought a 2000 Scrambler 500 & the clutch engages @ a higher RPM than I'm use to. I had a 98 Sportsman & when u gassed it it went. The Scrambler needs 1/8 to 1/4 throttle to engage. The last owner said the clutch was not stock. Should I be concernerd? It engages at the same time FWD & RVS & pulls fine from there on out. Leave it & try it or ? Thanks!
Old 02-10-2008, 08:48 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should've asked him what he had in it for a clutch kit or differnt springs. if you dont like how high it is then its an easy fix by changing springs once you pull the cover off. ask ftwflt what the stock set up is and he mostly can help you out since hes delt alot w/ his scrambler.
Old 02-10-2008, 09:39 AM
ftwflh's Avatar
Pull the clutch cover off and let me know what color of spring is in your front clutch.Should be blue with green.If you want stock clutching drop me a pm.
Old 03-04-2008, 04:48 PM
So I finally pulled the cover and looked at the clutch. The spring is silver. This is stock? I took the scrambler out last week and did some hill climbing. It seemed as if it wasn't hooking up fully at higher rpm's. Could this be the buttons I've read about? Should I rebuild the front & rear clutches? Thanks
Old 03-04-2008, 04:53 PM
Oh yea, does anyone know the belt width? Mine measures about 1 5/32"
Old 03-04-2008, 04:54 PM
sjbr549's Avatar
a new belt could help out too
Old 03-04-2008, 05:06 PM
sprinter10's Avatar
if you whant to go stock i will take what you have now i was looking for an cluth upgrade.
Old 03-04-2008, 07:08 PM
ftwflh's Avatar
If you can get hold of the previuos owner find out what brand of clutch kit he put in.Then I can try to help you out.
Old 03-04-2008, 07:26 PM
Is a silver spring stock for the front? I just replaced my secondary clutch buttons, any recommendations for the spring setting? I've seen 2-2 while researching. Is this OK for fast trail riding? Thanks guys!
Old 03-04-2008, 08:07 PM
sprinter10's Avatar
no that is not stock.
Quick Reply: 2000 Scrambler clutch engagement RPM?
