help needed with clutch kit/rejetting
Old Feb 13, 2008 | 03:03 PM
biff009's Avatar
Default help needed with clutch kit/rejetting
i have a 2000 scrambler 500 4x4 recently added a full dg exhaust. my question is i want to add a CLUTCH KIT and also a jet kit can someone let me know what a combination would be with the dg exhaust
Old Feb 13, 2008 | 03:48 PM
onesavage's Avatar
CALL RICK RITTER of rcr raceing or give AAEN performance a call or check hot seat perfromance
Old Feb 14, 2008 | 12:37 PM
biff009's Avatar
thanks for the info, can anyone add to this to help me out
Old Feb 14, 2008 | 12:40 PM
biff009's Avatar
i found a Bikeman Performance clutch kit and also a dynojet carb. jet kit
please give some opinions if anyone has these items installed
thanks
Old Feb 14, 2008 | 07:59 PM
ftwflh's Avatar
You shouldnt need to rejet with that exhaust and on the clutch kit go with a Dalton blk/white primary spring and set the secondary to 2-2
Old Feb 14, 2008 | 08:15 PM
biff009's Avatar
is this what i'm loooking for Includes our billet flyweights, a new primary spring, a new secondary spring, and a custom billet helix
Old Feb 14, 2008 | 11:06 PM
ftwflh's Avatar
If you are going with a complete kit go with either HPD or Dalton they are the best around
Old Feb 15, 2008 | 03:14 PM
biff009's Avatar
it is a DALTON
what can i expect for peformance out of this kit??
is it worth spending close to 300 for??
Old Feb 15, 2008 | 06:10 PM
ftwflh's Avatar
For that kind of $$$$$ I would get a TEAM roller secondary from HPD and go with a Polaris white primary spring.
Or ask Dyral at HPD what spring and weights he recomends with the TEAM clutch.
The roller clutch was the biggest improvment I have ever done on my Scrambler
Old Feb 15, 2008 | 06:53 PM
biff009's Avatar
can you give me the addy and maybe part#'s so i can check this out
