07 Deluxe Rims??
Old Feb 17, 2008 | 11:33 AM
ZAK3232's Avatar
Default 07 Deluxe Rims??
I was just wondering if anyone has had any problems with rims rusting? I have a 07 500EFI Sportsman Deluxe with the factory aluminum rims. I'm noticing some rusting on the rims and not sure if I should be scubbing away at it or bring it in to the dealer. Is this normal or not??
Old Feb 17, 2008 | 11:37 AM
700 sportsman's Avatar
i had some of that and I used son armor all wheel cleaner and came pretty easy
Old Feb 17, 2008 | 12:28 PM
sheepdogMSP8117's Avatar
Any of the machined surfaces of the rim will be subject to corrosion. I'd say that the dealer isn't responsible for that. Attention to detail by the owner comes into play here. The more often you clean and polish certain parts of your ATV, the longer they will look good.
Old Feb 17, 2008 | 01:02 PM
ZAK3232's Avatar
Ok guys I'll try that, thanks for the help!
Old Feb 17, 2008 | 01:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
ive had no issues w/ any of the alum. rims. they might corrode over time but they shouldnt rust if there alum.
Old Feb 17, 2008 | 09:00 PM
Arkyrider's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
ive had no issues w/ any of the alum. rims. they might corrode over time but they shouldnt rust if there alum.</end quote></div>
I have to agree on this one. Aluminum does not rust as it is not a ferrus metal. They can corrode but that usually only happens if the aluminum comes into contact with a corrosive material. Should not happen on a fairly new machine. Are yoyu sure you are not seeing mud stains?
Old Feb 17, 2008 | 09:35 PM
SCRAMMYTODD's Avatar
I've got rusty nuts and rusty center caps but no corrosion on the rims themselves.
Old Feb 18, 2008 | 10:56 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the crome plated lug nuts and caps can chip the cheap coating right off and rust like crasy for sure.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
fd24
Jan 16, 2019 08:59 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
