shock spanner wrench, which one is correct??
Old Feb 19, 2008 | 09:24 AM
lf479's Avatar
Default shock spanner wrench, which one is correct??
Would like to get a spanner wrench to adjust shock springs on my
2006 Sportsman 500. (Yeah I know I could use channel locks).
Online I can get them half price from what the dealer wants. However
there seems to be two different model wrenches and I cant find which
is the right one for me. OEM part numbers are 2870803 and 2870872.
Thanks for any help!
Les
Old Feb 19, 2008 | 09:41 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the one i got doesnt have a handle on it and it works but not the greatest. cant remember pn#
Old Feb 19, 2008 | 08:09 PM
brutus450's Avatar
i have a polaris spanner wrench and it SUCKS. it's too long to get in there and the "tooth" had to be ground down to fit into the notches of the adjuster. then By the time you line up the tooth to a notch on the adjuster the other end is banging into everything else to even get it to move. I guess it would work ok if you take your tire off but who wants to do that just to adjust the shocks? Use large channel locks.
Old Feb 19, 2008 | 08:20 PM
upnort's Avatar
I have just always used the one that came with my sled, has about a 4-5" handle.
Old Feb 20, 2008 | 08:26 AM
lf479's Avatar
Okay, I have heard from others as well and the consensus is to forget being proper and using the 'correct tool' in this case. Spoke to a friend of a friend at a dealership and they said they just use channel lock 460's (with a rag) to adjust as the spanners aren't that great. Thanks for the replies. I am just starting out with a used quad and am trying to do things the right way...
Old Feb 20, 2008 | 08:59 AM
ThreQtrWlf's Avatar
I picked up a universal one for $15 at the local cycle shop. It has a different size on each end. Worked good on my Scrambler. My neighbors chipped in $5 apiece so they could use it whenever needed, so my cost was $5.
Old Feb 23, 2008 | 08:53 PM
Indslpwr04's Avatar
I tried useing channel locks but al idid was chew up the adjusting collar. When i tried a rag it slipped to much. I found the one from my scrambler but haven tried it yet.
Old Feb 24, 2008 | 09:32 AM
Kerbbirds's Avatar
Jack up the rear end and spray the adjuster with some wd-40, I have a spanner wrench but find channel locks work better.
lf479's Avatar
Just as an update.. I used a big set of channel locks (model 460). Jacked the quad up to take tension off the springs.
Worked fine without rag, no damage, adjustment done. I think the trick is to get the load off the springs AND make
sure you have a big enough set of channel locks that can grab the ring/collar properly.
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
